Vieux 08/02/2010, 19h10
Mitch82
Avatar de Mitch82
Mitch82 has a spectacular aura aboutMitch82 has a spectacular aura aboutMitch82 has a spectacular aura about
Par défaut emulateur
bonsoir
ci joint la photo de l'emulateur correspondant au schéma
du post précédent, pas de code pour ce Rar
et le texte explicatif:
After decoding of Renault injection computer using our Reset Toolor
by entering security code, in most cases vou can start engine, but sorne
of injection computers can not operate without immobilizer code stored
in their memory. Here is a list of systems that require to be "Iearnt" with
immobilizer code: diesel EDC1S0, DCU3R and MSA1S, petrol SIRIUS32
(except these for 1.41engine) and FENIXS for 2.01 16V engine. If ail of
immobilizer components are OK, not coded ECU is "Ieamt" after first
ignition-on and car engine will start. ln the case of immobilizer
malfunction Renault Immobilizer Emulator can be used. This easy-toconnect
device emulates valid immobilizer signal and is suitable for ail
diesel and petrol engine computers produced in the range of year 1996-
2001. It does not work on engine control unit manufactured before year
1996 (IMM01) and after year 2001 (IMM03). Order of work is simple -
decode engine control unit, cut original immobilizer data line
(important!), put this small board in to box of ECU(or connect it outside)
and on first power-on computer will retain code, transmitted by
emulator.
Dernière modification par Mitch82 ; 15/10/2011 à 07h31.
Mitch82 est déconnecté   Réponse avec citation
The Following User Says Thank You to Mitch82 For This Useful Post:
digicar (13/04/2011)
