Vieux 10/03/2014, 01h26
nbfour
Avatar de nbfour
nbfour is an unknown quantity at this point
Bonsoir, essaye de suivre ces étapes :
1. Plug your K+D-CAN cable and install drivers. For FTDI based cables use latest drivers from C:\EDIABAS\HARDWARE\OBD\FTDI folder.
2. Open "Device Manager", then USB Serial Port properties, go to "Port Settings" tab and click "Advanced...". Change port number to "COM9" and latency timer to "1". Confirm configration via "OK" button.
ScreenShot ScreenShot
3. Open C:\EDIABAS\BIN\EDIABAS.INI with Notepad and check for "Interface = STD:OBD".
ScreenShot
4. Open C:\EDIABAS\BIN\OBD.INI with Notepad and check for "Port=Com9".
ScreenShot
5. Now run BMW Rheingold ISTA and wait until it boots, then press settings button.
ScreenShot
6. Select "VCI Config" tab and "Ediabas standard settings (ediabas.ini)", then "OK".
ScreenShot
7. Go "Identification", then "Read Out Vehicle Data" and "Start Vehicle Test".
nbfour est déconnecté   Réponse avec citation
The Following User Says Thank You to nbfour For This Useful Post:
vortex (18/03/2014)
