Discussion: problème bmw 318i
Vieux 11/03/2014, 09h25
jasonics
Avatar de jasonics
jasonics is on a distinguished road
Envoyé par technicien Voir le message
merci je vais vérifier tout cela.
yes u probably have awire short circuitto 12volts,thats why it goes out of limit,u can read up to 3000mv,this will cause idling upand down,when ecu try tomake corrections.ope this helps,i had similar situations.
Envoyé par jasonics Voir le message
plz chk from conector fromecu to lampda, ,unplug it read from ecu connector voltage received,if its out of tolerance ,cut wire from ecu pin ,make new wire to plug,thats wat was happening to my cars,had abt 5 cars with this situation.
Dernière modification par cedrsan ; 11/03/2014 à 11h19.
jasonics est déconnecté   Réponse avec citation
