Vieux 15/03/2014, 13h47
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 185
Envoyé par jimm222 Voir le message
ou si possible avoir un schema du edc15c7.merci
J'ai trouvé ça sur le net , le schema n'est pas dispo sur autodata !
Fiat ecd15C7
1 - Earth
2 - Earth
3 - Earth
4 - Actuator supply
5 - Injector/ECU supply
6 - Not connected
7 - Not connected
8 - Not connected
9 - Fast FL CAN line
10 - Fast FL CAN line
11 - Immobilizer
12 - Not connected
13 - Injection relay
14 - Not connected
15 - Throttle solenoid actuator for control on deactivation
16 - E.G.R. actuator
17 - VGT solenoid actuator
18 - Air conditioner relay
19 - Request to switch on fans 2nd speed
20 - Request to switch on fans 1st speed
21 - Injection warning light
22 - Spark plug activation
23 - Fuel filter relay
24 - Fuel pump relay
25 - Not connected
26 - Not connected
27 - Not connected
28 - C-CAN L
29 - C-CAN H
30 - Not connected
31 - Not connected
32 - Not connected
33 - Not connected
34 - Not connected
35 - Not connected
36 - Not connected
37 - Not connected
38 - Not connected
39 - Not connected
40 - Not connected
41- Not connected
42 - Not connected
43, Not connected
44, Not connected
45, Not connected
46, Not connected
47, Not connected
48, K line
49, Not connected
50, Not connected
51, Quadrinary on
52, Trinary on
53, Cruise control
54, Brake switch signal (released)
55, Cruise control
56, Cruise control
57, Cruise control
58, Key sense
59, Brake switch signal (pressed0
60, Request to switch on air conditioner
61, Clutch pedal switch
62, Spark plug fault diagnosis
63, Not connected
64, Not connected
65, Not connected
66, Not connected
67, Not connected
68, Not connected
69, Not connected
70, Not connected
71, Not connected
72, Not connected
73, Not connected
74, Not connected
75, Not connected
76, Accelerator 1 pedal earth
77, Accelerator 1 pedal
78, Accelerator 1 pedal power supply
79, Accelerator 2 pedal earth
80, Accelerator 2 pedal
81, Accelerator 2 pedal power supply
82, Fuel temperature sensor - pin 1
83, Fuel temperature sensor - pin 2
84, Water temperature sensor - pin 1
85, Water temperature sensor - pin 2
86, Air flow meter - pin 1
87, Not connected
88, Air flow meter - pin 3
89, Air flow meter - pin 5
90, Fuel pressure sensor - pin 3
91, Fuel pressure sensor - pin 2
92, Fuel pressure sensor - pin 1
93, Turbocharging pressure sensor - pin 1
94, Turbocharging pressure sensor - pin 3
95, Turbocharging pressure sensor - pin 2
96, Not connected
97, Air flow meter - pin 4
98, Engine oil pressure switch
99, Rpm sensor - pin 1
100, Rpm sensor - pin 2
101, Not connected
102, Timing sensor - pin 1
103, Timing sensor - pin 2
104, Timing sensor - pin 3
105, Swirl position feed back
106, Not connected
107, Not connected
108, Diesel pressure regulator
109, Diesel pressure regulator
110, Not connected
111, Not connected
112, Not connected
113, Not connected
114, Cylinder 4 injector control
115, Not connected
116, Not connected
117, Cylinders 1-2 injectors shared
118, Cylinder 3-4 injector common
119, Cylinder 1 injector control
120, Cylinder 2 injector control
121, Cylinder 3 injector control
___________________________
www.123diagauto.com
diagnosis29 est déconnecté
The Following User Says Thank You to diagnosis29 For This Useful Post:
jimm222 (15/03/2014)
