Discussion: Ref ecu
Vieux 18/02/2010, 20h20
ricards99
Avatar de ricards99
ricards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond reputericards99 has a reputation beyond repute
j'espere que ca repond a ta question : tout est la
xsara II immatricule le 10/04/2001 couleur vert lonchamp metalisee vernie interieur velour cesium
MOTEUR DIESEL TURBO DW10TD DÉTECTEUR D'EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE FONTE CARBURANT GAZOLE DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR) MOTEUR (TYPE) MOTEUR TYPE EW/DW REFROIDISSEMENT D'HUILE ECHANGEUR EAU/HUILE MOTEUR MOTEUR REFROIDISSEMENT RADIATEUR EP:27 - 21 DM2 ALU BRASE RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC EOBD DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4 VENTILATEUR 1 VENTILATEUR 3 VITESSES 420W VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH MOTEUR HYBRIDE SANS ALTERNO-DEMARREUR BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
ricards99 est déconnecté   Réponse avec citation
