Discussion: Probleme Reinghold
Vieux 20/04/2014, 20h26
sntyad
Avatar de sntyad
sntyad has a spectacular aura aboutsntyad has a spectacular aura about
pour utiliser rheingold, avec k+dcan :
1. Plug your K+D-CAN cable and install drivers.
2. Open "Device Manager", then USB Serial Port properties, go to "Port Settings" tab and click "Advanced...". Change port number to "COM9" and latency timer to "1". Confirm configuration via "OK" button.
3. Open C:\EDIABAS\BIN\EDIABAS.INI with Notepad and check for "Interface = STD:OBD".
4. Open C:\EDIABAS\BIN\OBD.INI with Notepad and check for "Port=Com9".
5. Now run BMW Rheingold ISTA and wait until it boots, then press settings button.
6. Select "VCI Config" tab and "Ediabas standard settings (ediabas.ini)", then "OK".
7. Go "Identification", then "Read Out Vehicle Data" and "Start Vehicle Test".
Cherche solution pour lire et ecrire les Tricore via cmd1255 / Upa.
sntyad est déconnecté   Réponse avec citation
