Discussion: P 1601 toyota hilux
Vieux 12/05/2014, 22h29
Shadab
Avatar de Shadab
Shadab is on a distinguished road
To read, save, write old injectors values in new ecm or write new injectors values in old ecm, you can also use Autoboss V30, Toyota Tech stream version 8.10.021 or any other version with Tectrix or Mongooses, which is available to you.
- Connect the scanner to DLC3, open the software, switch the ignition to ON (Do not start the engine).
- Press CONNECT, select OPTIONS, select with or without smart key, and press OK or NEXT.
- Press UTILITY and select Change injector values.
- Follow on screen instructions.
Thanks.
Shadab est déconnecté   Réponse avec citation
The Following User Says Thank You to Shadab For This Useful Post:
diago2001 (13/01/2021)
