Vieux 09/06/2014, 02h04
Nizar-maoukil
Avatar de Nizar-maoukil
Pouvoir de réputation: 24
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
salur rahmani
voici comment coriger le checksum avec winols
Correcting checksums is very easy because this is often done by additional plug-ins. These must be purchased separately but for this they also do all the work needed automatically.
Start the checksum dialog with the menu item "Edit" / "Checksum" (Hotkey F2). Click on "Search". If you own the right checksum module, it will automatically be applied and the checksum will be calculated and (if you want that) always be corrected.
If you do not have the matching module, you can let EVC check your project for free and without any commitments. Click on "Search checksum online". The project will be compressed and uploaded to the EVC server (Internet connection required). A few seconds later you will receive an answer, telling you which checksum module will work for your data.
Important: Some checksum modules require an unmodified original version. That means, that you must have loaded the original data from the car as original version into the WinOLS project. Otherwise it may happen that the checksum is not recognized or not calculated correctly.
best regards
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to Nizar-maoukil For This Useful Post:
hugo431 (30/06/2014), jeanalitre (15/11/2018), lenoob (16/06/2014), MOURAD SPCMAX (09/06/2014), pp08 (21/12/2020)
