Vieux 18/07/2014, 12h08
redpoker
Avatar de redpoker
Pouvoir de réputation: 30
redpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant futureredpoker has a brilliant future
ta le schema?
y va aussi au calculo,tu as l EGR sur la meme ligne, debranche l egr efface t defaut,fait un essai et recontrole le si le capteur ressort, le voyant sera allume lui.
Je regarde pour le schema, sinon contact MecaTech y va t dire si y a des precedents pour ton calculo et si ta besoin d autre info.
redpoker est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to redpoker For This Useful Post:
bloker (18/07/2014), MecaTech (18/07/2014)
