Discussion: siena
Vieux 23/08/2014, 07h18
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
Traduction
1-Eletroinjetor : injecteur__2-Eletroventilador : ventilateur electrique__3-rele principal : relais principal__4-T.água : T.eau__ 5-Temp.Ar : Temp. Air__6-Pressão absoluta : Pression absolue__7-bobina de ignição : Bobine d'allumage__8-Bomba combustível : pompe à carburant__9-Massa sensores : Masse (terre) capteurs__10-Alimentação de sensores : Alimentation capteurs__11- aterramento : Masses (terre)__12-corpo da borboleta : corp du papillon.
Pour le shemas pas entre trouvé , mais je vais chercher.
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Drogo est déconnecté   Réponse avec citation
The Following User Says Thank You to Drogo For This Useful Post:
sathicham (23/08/2014)
