Discussion: AL4 Programming
Vieux 24/08/2014, 07h19
Mike H
Avatar de Mike H
Mike H will become famous soon enoughMike H will become famous soon enough
Envoyé par Simple Voir le message
@ Mike H,
Thanks, the link has been removed. However, I think you may be referring to a Lexia 3 device. I have ordered one already and I hope to be able to do this.
Now I need a repository to download the ECU firmware so that I can update them.
Thanks again, Simple.
Effectively, I don't remember this rule of the forum. I'll never put a direct line to another forum on an answer @diagnosis29
You're right for your answer, the only way to reset is an interface, like the Lexia.
I've seen that this problem often happens on an automatic C8.
At the begin, it's enough to turn off the engine, wait a few moment...
But later, you're in the problem. They also talk about E/V witch also can made a problem with this car
[SIGPIC][/SIGPIC] Si vous croyez qu'un professionnel va coûter cher, tentez l'aventure avec un amateur
Mike H est déconnecté   Réponse avec citation
