Discussion: Peugeot 206 immo
Vieux 12/09/2014, 00h11
sauzee1
Avatar de sauzee1
sauzee1 is an unknown quantity at this point
Par défaut Peugeot 206 immo
Hi i have a peugeot 206 1.4 51plate came in with non starting due to ecu failure
i changed the ecu,bsi and decoder ring but i didn't have the pod for the key.
Originally the fuel pump wouldn't operate as the ecu was not working the parts were from a donor car but the keys were away pump operates fine now but must be immobilized as pod wont match
My question is can i bypass immo to check it will run or do i need to have it reprogrammed or which diagnostic machine can i use to get it running
Thanks for any help
sauzee1 est déconnecté   Réponse avec citation
The Following User Says Thank You to sauzee1 For This Useful Post:
degradamus (11/11/2014)
