Do you have op-com as I suppose when Astra H deplyment data could be erased with procedure:
Choose SDM Airbag
Read faultcodes
Choose Programming
Choose Clear deployment record
Select parameters from dropdownlist
Choose Start activation
Close communication with SDM Airbag module and disconnect the interface
from car
Lock the car using the remote
Wait at least 15 seconds
Unlock the car using the remote
Reconnect to the SDM Airbag module
Clear faultcodes from SDM Airbag module
The interior light will stay on now
Disconnect negative terminal from battery
Wait at least one minute
Reconnect the negative terminal to battery
Interior light will work fine now
Otherwiser send you crash dump.
Dernière modification par morfej ; 09/06/2010 à 17h48.
