Discussion: Peugeot 206 immo
Vieux 15/09/2014, 21h19
sauzee1
Avatar de sauzee1
sauzee1 is an unknown quantity at this point
Envoyé par Ecuserver.net Voir le message
hi,
first you need to give us a diag report,
then after it will be easy to find the solution, give me the ref for ecu to tell you if possible to bypass immo or not !
Hi i forgot to lift the paper with the ECU number on it but i tried to read the codes with my autocom it would not recognise the Ecu but i got it to work on the Multifunction tab where it said
- Key programming not done
- Present
- - Key programming not done
- Intermittent
- - Communication, engine management unit
- Present
- Intermittent
- - Remote control programming not done
- Intermittent
- - Battery in remote controller exhausted
- Intermittent
I then put in the old Ecu,Bsi and ring decoder read the codes again still no communication apart for Multifunction where i cleared the codes but no sound from the fuel pump and wouldn't start
Thanks for any help
sauzee1 est déconnecté   Réponse avec citation
The Following User Says Thank You to sauzee1 For This Useful Post:
degradamus (11/11/2014)
