Discussion: immo off "safir2"
Vieux 22/09/2014, 16h58
sandy976
Avatar de sandy976
sandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to allsandy976 is a name known to all
si c'est un 55 pin, ça doit marcher comme suit :
driver Sagem Safir2 with 55 pins
1 +12V
2,3,18 ground
37 immo - cut off
43 engine lamp
40 the main relay control
48 fuel pump relay control
Solder wire to 22th leg of
unit 27c512 !!!
Power the driver by voltage 9 V.
While serve the power touch wire from leg 22
to the ground.
This will cause disrupt of the transmission
and unlock the driver
sandy976 est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to sandy976 For This Useful Post:
br25 (23/09/2014), hadil (22/09/2014), poze (29/09/2014)
