Discussion: vcds code acces
Vieux 15/10/2014, 13h23
diagnosis29
Avatar de diagnosis29
Pouvoir de réputation: 185
Envoyé par Verdun Voir le message
merci j ai regarder mais je trouve pas exemple pour calculateur d airbag d une tiguan annee 2007 et calculateur airbag audi a3 2006
VW Tiguan (5N) Airbag VW10
Adaptation
Used to deactivate individual airbag components (see repair manual for details).
Basic Setting
Seat Occupied Recognition Control Module (J706)
If the Seat Occupied Recognition Control Module (J706) or the seat itself have been replaced, the basic setting has to be performed.
[Select]
[15 - Airbags]
[Security Access - 16]
Enter 10522, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The reset has been performed.
[Done, Go Back]
[Close Controller, Go Back - 06]
Special Procedures
Seat Occupied Recognition Control Module (J706): Reset
If a repair on the Seat Occupied Recognition has been performed, a reset has to be performed too.
Prerequisites:
Seat in normal position.
Seat must NOT be occupied during the whole procedure.
Seatbelt must NOT be plugged in.
No faults in the system.
Interior temperature must be between 0 °C and 37 °C (32 °F and 98 °F).
[Select]
[15 - Airbags]
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[Save]
[Done, Go Back]
Audi A3 (8P) Airbag 9.41
[Select]
[15 - Airbags]
Enter 30475, to enable the basic setting.
If you are having problems performing this security access, contact us.
[Do it!]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Special Procedures
Prerequisites:
[Select]
[15 - Airbags]
[Do it!]
[Adaptation - 10]
Channel 000
[Read]
[Save]
[Done, Go Back]
source : http://wiki.ross-tech.com/wiki/index.php/Main_Page
___________________________
www.123diagauto.com
Dernière modification par diagnosis29 ; 15/10/2014 à 13h27.
The Following 6 Users Say Thank You to diagnosis29 For This Useful Post:
diagprog (15/10/2014), domidom (24/10/2014), Draag0 (27/01/2015), jah83 (27/12/2014), natouss225 (16/10/2014), Verdun (15/10/2014)
