Discussion: MB Star Vediamo info
Vieux 18/10/2014, 05h19
Nizar-maoukil
Avatar de Nizar-maoukil
Pouvoir de réputation: 23
Nizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud ofNizar-maoukil has much to be proud of
hi dud
Vediamo - engineering software for Mercedes.
Version 03.2012, the original software, without curves interventions.
program is designed to fulfill all the functions available blocks of various systems.
does not require any input password and codes.
All features are available from the program blocks of old and new cars.
engineering functions missing in standard inzhenerki das and ksentri, especially on new models in ksentri almost nothing, and this program can be very much in the new models.
briefly, coding, flash, CCN encoding (read, save, transfer to another unit), the error read, delete (remove from memory, even those that normally inzhenerki not removed), the variant encoding CCN = disable the use of systems and sensors via the disabling code encodings, and much much more ...
if u need to buy contact me in privet message
regards
Mercedes esl repair programing and renew
bmw E90 and E60 esl off ( car runs without esl )
regards
Nizar-maoukil est déconnecté   Réponse avec citation
The Following User Says Thank You to Nizar-maoukil For This Useful Post:
diagprog (21/10/2014)
