Vieux 20/10/2014, 22h32
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 27
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
sinon iot par la prise 500 euro c'est le moins cher ...
mais attention !!
faut savoir ce que tu fais !
WARNING flash write functions only for advanced users who know what they are doing.
Do not use flash write functions unless you have some BDM tool for flash restoring.
"Write Flash M58BW016DB No Boot" writes external flash but leaves bootloader unchanged
this is safe function for external flash to write.
"Write Flash M58BW016DB Full" writes full external flash. This is dangerous
function for external flash to write. In case of power loss you will have
to restore flash using BDM tools.
"Write Flash MPC563" writes full internal flash of MCU MPC563. This is dangerous
function for inernal flash to write. In case of power loss you will have
Kennfeld est déconnecté   Réponse avec citation
