Vieux 27/10/2014, 06h45
bubu782001
Avatar de bubu782001
bubu782001 is on a distinguished road
IAW5NR immo off only with emulator (this is for Twingo from 2000 - 2004).
Also is working for Clio and Kangoo produced until 2002 (with white box BMT sagem or UCE decoder with blue connector).
For Clio, Kangoo produced after 2002 (black box Sagem UCH) coding for this ECU is made on CAN - so only transponder id46 is the solution.
If you write protect eeprom 95160 you will loose the possibility to save auto-adaptive settings from ECU (boitier pappilon apprentissages). The car will accelerate very poor and you will have problems with acceleration.
Sorry for i don't speak french.
Hope it helps.
bubu782001 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to bubu782001 For This Useful Post:
lenaic (27/10/2014), NABILOV (22/12/2023)
