Discussion: full flash bdm
Vieux 09/11/2014, 11h39
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
Reprogr. Ecu BDM
1.Démonter le boitier (ECU)
2.Localiser les emplacement ou se connecter
3.Connecter l'adaptateur sur la carte
4.Mettre sous tension le boitier et lire l'Eprom Flash et/ou le processeur
5.Modifier le programme
6.Remettre sous tension le boitier et puis reprogrammer l'Eprom Flash et/ou le processeur
7.Recoder le boitier puis le remettre en place
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Drogo est déconnecté   Réponse avec citation
The Following 4 Users Say Thank You to Drogo For This Useful Post:
diagprog (09/11/2014), electro_bordeaux1 (09/11/2014), MOURAD SPCMAX (09/11/2014), rosaire974 (09/11/2014)
