10/11/2014, 16h01
Pouvoir de réputation: 40
j'espere que c'est que tu cherche,je t'ai copier coller toute la page d'instructions.
KESS V2
Since the wake up error appeared, xcardiag engineers have a search on it, and found that if the card is not formatted first, the error will occur if you do as the solutions.
That is to say, no the solutions are with one more step, format card, and then copy the programs (download programs from http://*****************************...**************.) in the TF card.
If you are forgetting the three solutions, I am here sharing you once more:
1. Have a replacement of programs in the TF card.
2. Follow the installation video of certain version
3. Reprogram CPU program in the way of solving tokens limitation.
Tip: Format card first
Kess v2 wake error is not difficult to solve and could also work well after have its card replaced or install certain version by following video or reprogram CPU well in the way of solving tokens limitation.
Dernière modification par cedrsan ; 10/11/2014 à 20h54.
