Discussion: immo off boxer 2l hdi
Vieux 14/11/2014, 08h08
nimbus
Avatar de nimbus
Pouvoir de réputation: 73
nimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond repute
slt ds tes parametre a tu la possibilite de voir si ecu verouille ou deverouiller??pour eliminer le probleme adc si ok
je dirais pompe hp hs ou injecteur grosse fuite sur retour vu que le rail monte pas en pression si la pompe hp est reste + ou moin vide
nimbus est déconnecté   Réponse avec citation
The Following User Says Thank You to nimbus For This Useful Post:
Malfra90 (14/11/2014)
