Vieux 16/11/2014, 14h26
Drogo
V.I.P
Avatar de Drogo
Pouvoir de réputation: 90
Drogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond reputeDrogo has a reputation beyond repute
SIRIUS32 SANS CAN
1 → IGNITION COIL 2-3 CONTROL
32 → IGNITION COIL 1-4 CONTROL
3 --- POWER EARTH
33 --- POWER EARTH
4 → CANISTER PURGE CONTROL
8 → FAN ASSEMBLY RELAY 1 CONTROL BY CCTM
38 → FAN ASSEMBLY RELAY 2 CONTROL BY CCTM
9 → COOLANT TEMPERATURE WARNING LIGHT
39 → ACTUATOR RELAY CONTROL
10 → AC COMPRESSOR CONTROL
41 → IDLE SPEED REGULATOR CONTROL (TRACK A)
12 → IDLE SPEED REGULATOR CONTROL (TRACK B)
42 → IDLE SPEED REGULATOR CONTROL (TRACK C)
13 ← COOLANT TEMPERATURE SENSOR INPUT
43 ← THROTTLE POTENTIOMETER SIGNAL
15 --- PRESSURE SENSOR EARTH
45 ← OXYGEN SENSOR SIGNAL INPUT
63 → OXYGEN SENSOR HEATER CONTROL
64 → CAMSHAFT OFFSETTING DEVICE CONTROL
65 → GEAR CHANGE INDICATOR LIGHT CONTROL
66 --- +AFTER IGNITION
68 → FUEL PUMP RELAY CONTROL
70 → TDC ENGINE SPEED INFORMATION
72 → IDLE SPEED REGULATOR CONTROL (TRACK D)
73 --- COOLANT TEMPERATURE SENSOR EARTH
74 --- THROTTLE POTENTIOMETER SUPPLY
75 --- THROTTLE POTENTIOMETER EARTH
16 ← MANIFOLD PRESSURE SENSOR SIGNAL INPUT
19 --- KNOCK SENSOR SHIELDING
49 ← AIR TEMPERATURE SENSOR INPUT
20 ← KNOCK SENSOR SIGNAL INPUT
23 ← AC COMPRESSOR POWER ABSORBED INFORMATION
53 ← VEHICLE SPEED INPUT
24 ← ENGINE SPEED SENSOR SIGNAL INPUT
54 ← ENGINE SPEED SENSOR SIGNAL INPUT
26 --- DIAGNOSTIC
56 --- DIAGNOSTIC
28 --- POWER EARTH
58 ← ENGINE IMMOBILISER SYSTEM
29 --- +AFTER IGNITION
59 → INJECTOR 1 CONTROL
30 --- +BEFORE IGNITION
60 → INJECTOR 3 CONTROL
77 --- AIR TEMPERATURE SENSOR EARTH
78 --- PRESSURE SENSOR SUPPLY
79 --- KNOCK SENSOR EARTH
80 --- OXYGEN SENSOR EARTH
85 → POWER STEERING PRESSURE SWITCH INFORMATION
89 → INJECTOR 4 CONTROL
90 → INJECTOR 2 CONTROL
SIRIU32 AVEC CAN
PIN 57=can L
PIN 27=CAN H
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Drogo est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to Drogo For This Useful Post:
CHATONDU38 (30/11/2014), diagprog (30/11/2014), fethidiag (23/12/2014), nimbus (15/01/2015), seko (16/11/2014)
