Vieux 18/12/2014, 14h21
karera 1
Avatar de karera 1
Pouvoir de réputation: 27
karera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud ofkarera 1 has much to be proud of
salut poste ton dump originale d'abord il vault mieux toujours le faire a partir de ton originale normalement tu peu reprogrammer ton code pin aussi mais explique le pourquoi de ce off c'est quoi le probleme !
parfois la solution au probleme et dans la question !
karera 1 est déconnecté   Réponse avec citation
The Following User Says Thank You to karera 1 For This Useful Post:
chekosse (18/12/2014)
