Discussion: Kangoo 1.5dci Egr
Vieux 23/12/2014, 18h37
sauzee1
Avatar de sauzee1
sauzee1 is an unknown quantity at this point
Par défaut Kangoo 1.5dci Egr
Hi i wonder if anyone has had the same problem with an egr fault i have error codes
DF027 - EGR solenoid valve circuit, at minimum limit
- Permanent
DF084 - EGR valve position sensor circuit, above maximum limit
- Permanent
I have changed the egr for a working one and still the same codes The problem is the van has no power 25mph up hill and 40mph down hill there is no eml on the dash .I have plugged it into Autocom and when i activated the egr when it is removed the solenoid operates up and down so it shouldn't be wiring or egr can it be a air leak or something else or am i better buying a blanking plate for egr
Thanks for any info
sauzee1 est déconnecté   Réponse avec citation
