18/02/2015, 20h28
V.I.P
Pouvoir de réputation: 90
Résoudre sans crack
Retour , j'ai fait ce qu'il y a en dessous et pour l'instant ça marche.
How to Make your Windows XP SP2/SP3 ******* -No Crack or Activator needed
This method doesn't requires you to do a Reinstall or download risky softwares or cracks.
First we will de-activate windows and then change the product key.No restart is required.Lets begin
(Do it at your own risk)
Heres how
Click on Start and then Run.
In the text box in the Run window, type regedit and click OK. This will open theRegistry Editor program.
Locate the HKEY_LOCAL_MACHINE folder under My Computer and click on the (+)sign next the folder name to expand the folder.
Continue to expand folders until you reach theHKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT \Current Version\WPAEvents registry key.
Click on the WPAEvents folder.
In the results that appear in the window on the right, locate OOBETimer.
Right-click on the OOBETimer entry and choose Modify from the resulting menu.
Change at least one digit in the Value data text box and click OK. This will deactivateWindows XP.
Feel free to close Registry Editor at this point.
In the text box in the Run window, type the following command and click OK.
%systemroot%\system32\oobe\msoobe.exe /a
When the Let's activate Windows window appears, choose Yes, I want to telephone a customer service representative to activate Windows and then click Next.
Click the Change Product Key button at the bottom of the window.
Don't worry about filling anything out on this screen.
Type your new, valid Windows XP product key in the New key: text boxes and then click the Update button.
Windows XP Service Pack 2 (SP2) ******* Serial Key
XXXX-XXXX-XXXX-XXXXX-XXXXX
Windows XP Service Pack 3 (SP3) ******* Serial KEy
XXXX-XXXX-XXXX-XXXX-XXXX
You should now reactivate Windows XP by following the instructions on the Activate Windows by phone window which you should now be seeing or via the Internet by clicking the Back button and following the instructions on that screen.
If you'd rather postpone activating Windows XP until a later date, you can click theRemind me later button.
After activating Windows XP, you can verify that activation was successful by repeating steps 9 and 10 above.
The Windows Product Activation window that appears should say "Windows is already activated. Click OK to exit."
pour les clés d'activation demander
J’aime · · Partager
ESPERAR E SABER ESPERAR É UMA GRANDE VIRTUDE
Dernière modification par cedrsan ; 18/02/2015 à 22h41.
