Discussion: Prob Golf 6
Vieux 07/03/2015, 18h48
yacine27000
Avatar de yacine27000
yacine27000 is just really niceyacine27000 is just really niceyacine27000 is just really niceyacine27000 is just really nice
16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
Possible Symptoms
Reduced Power Output
Limp Mode
Possible Causes
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
Turbocharger faulty
Diverter Valve faulty
Possible Solutions
Check Hoses/Pipes to/between Components
Check / Clean / Replace Charge Pressure Control
Check Turbocharger
Check Diverter Valve
Special Notes
When found in 2.0l TFSI:
Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06H-145-710-D (or newer).
RoW vehicles see: TPI 2016331 for details.
NAR vehicles see: TSB 01-07-70 or 2013392 for details.
When stored in conjunction with misfire codes and/or fuel trim faults see the notes associated with the following faults regarding PCV failure: Crankcase Breather Valve
If the Turbocharger is faulty due to mechanical / internal problems or the exhaust system is restricted (typically the Catalyst) this fault may be the end result.
When found in VW Golf/Jetta (1K): 2.0l CR-TDI (CBEA/CJAA):
Verify the mechanical part of the Exhaust Valve Control Module (J883) is not seized or binding.
When found in Audi A4/S4/RS4/Cabriolet (8K): 2.0l (CAEB):
See TPI 2031245/6 - turbocharger excessive waste-gate play
yacine27000 est déconnecté   Réponse avec citation
The Following User Says Thank You to yacine27000 For This Useful Post:
angeflasheur (07/03/2015)
