Vieux 11/03/2015, 09h31
matteo23
Avatar de matteo23
matteo23 is an unknown quantity at this point
Envoyé par paulodoria Voir le message
Hello,
Write the content to the 24c02 chip.
Your ECU is now virgin and can be put in any car.
If you want to totally disable the immobilizer just disconnect the immobilizer box.
test and report.
Hi, Thank You for your reply..
I tried your Immo Off, but unfortunatly it doesn't work..
I tried :
1) Without the Immobox , the car didn't start without the code light and the fans was switched on
2) With Immobox, the car didn't start and the fan was switched on, but the code light was turned on
Did you ever try this solution..?
thk YOU!
matteo23 est déconnecté   Réponse avec citation
