Vieux 18/03/2015, 21h41
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
bonjours.si ta voiture n a jamais ete accidente .elle est sous garantie non?ou ton default vient d une resistance trop elever dans le cablage,soit ceinture neuve pas conforme ou controle les prise(raccord) et le faisceau jusqu au boitier.merci.
magaratz est déconnecté   Réponse avec citation
The Following User Says Thank You to magaratz For This Useful Post:
Verdun (18/03/2015)
