Vieux 10/04/2015, 20h13
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
Bonjours ,probleme ralenti differer .il faut que tu me donne le code vao qui est ecrit sur la batterie ,je te le modifie et tu le remet en assistant depanage
avec odis ou vas.mais je sais pas si on peut faire ca avec delphi ,wow ou vcds.on a tester ca marche.merci.
magaratz est déconnecté   Réponse avec citation
The Following User Says Thank You to magaratz For This Useful Post:
thierry du58 (10/04/2015)
