Vieux 02/05/2015, 16h29
Psycho29
Avatar de Psycho29
Psycho29 is an unknown quantity at this point
Envoyé par paulodoria Voir le message
Thanks paulodoria, problem is that what you mention on that link uses the 4 pin code, and I only have the 7 digit SKC code, which also requests for additional info:
- Date on which the 7-digit SKC was retrieved by the Dealer.
- Workshop Code (WSC) for the Dealer that retrieved the SKC.
- Importer Number for the dealer that retrieved the SKC.
So at this point I haven't been able to do this swap using VCDS. Other hardware has been used, and all info from original cluster is available, but the new cluster (TTS one) is or seems to be blocked, so there is no access to it, and impossible to retrieve any kind of information from it, this is where everybody gets stuck. By the way, Luis, the owner of AD Electronica in Andorra is Portuguese, do you want me to ask him anything in particular in order to help me any further? Sending the cluster to someone would help?
Psycho29 est déconnecté   Réponse avec citation
