Vieux 17/06/2015, 17h19
electro_bordeaux1
Avatar de electro_bordeaux1
Pouvoir de réputation: 31
electro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud ofelectro_bordeaux1 has much to be proud of
Par défaut P1631 et U2107 opel astra G
Bonjour a tous les membres j ai une opel astra G Y17DT qui demare pas et lorsque je debronche la batterie et je le rebronche ça demare et cale d apres l opcom j ai les defauts suivant
OP-COM 100219a - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 2002 (2)|Astra-G|Engine|Y 17 DT
Keyword #1: EF
Keyword #2: 8F
Normal timing parameter set.
VIN: W0L0TGF692526xxxx
RepairShopCodeOrTesterSerialNumber: DELCOLVP13
ProgrammingDate: 20010815
systemSupplierECUHardwareNumber: DEL 0113386350
vehicleManufacturerECUHardwareNumber 97233370 DJ
systemSupplierECUSoftwareNumber: DLMD
systemSupplierECUSoftwareVersionNumber: 0002
exhaustRegulationOrTypeApprovalNumber: D01010
systemNameOrEngineType: Y17DTL
Identifier: 1321
CalibrationDate: STRCB0A
Total number of fault codes: 7
P0481 - Fan Relay 2 Signal Low / Open Circuit
(04) - Present
P0480 - Fan Relay 1 Signal Low / Open Circuit
(04) - Present
P1615 - <Unknown DTC>
(00) - Present
P1616 - <Unknown DTC>
(00) - Present
P0530 - A/C Refrigerant Pressure Sensor Circuit High Input
(01) - Present
U2107 - CAN-Bus no Communication with Body Control Module
(00) - Present
P1631 - Spill Valve Relay Voltage Low
(04) - Present
une piste a suivre et merci
l union fait la force
electro_bordeaux1 est déconnecté
