Vieux 01/07/2015, 13h22
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
:bonjours;du grand nimport quoi;il doit y avoir des default aillleurs.protectection des composants ;le boitier est pas reconnu parceque il faut faire remplacement de piece via vas ou odis;si la piece est d origine?et pourquoi tu as remplacer ton boitier?merci;
magaratz est déconnecté   Réponse avec citation
