Vieux 12/07/2015, 13h47
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
Par défaut citroen xsara picasso 1,6hdi 9HX def P0192
bonjours ,j ai un picasso 2008 injection 9HX ,j ai remplacer electrovanne et soupape EGR neuf (valeo) mais en essai perte de puissance et le def;P0192 circuit capteur pression pompe carburant A niveau bas ,ressort toujours ,faut le remplacer ou autre probleme connu?merci.
magaratz est déconnecté   Réponse avec citation
