Vieux 26/07/2015, 22h45
wscar
Avatar de wscar
wscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to beholdwscar is a splendid one to behold
un simple vag k+can feras l affaire pour lire le pin ensuite pour coder le nouveau compteur (occasion) un coup de vcds
extrait du manuel en ligne vcds
[Select]
[25 - Immobilizer]
[Security Access - 16]
For the following procedure, use the PIN of the NEW (USED) instrument cluster.
4-digit PIN
Enter zero followed by the 4-digit PIN. For example, if your PIN is 1234, enter 01234.
[Do it!]
The instrument cluster now shows Immobilizer Adaptation active, wait until it changes to Immobilizer active - this may take up to 2 Minutes.
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
For the following procedure, use the PIN of the OLD (ORIGINAL) instrument cluster.
4-digit PIN
[Test]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
ensuite il te reste le codage des clees
25 - Immobilizer]
[Meas. Blocks - 08]
Select Block 001.
[Go!]
The value in field 3 must be Yes. If value is No, the key is not capable of being adapted to Immobilizer.
You can check each key in this manner.
Select Block 003.
[Go!]
Make sure the shown lock times in field 1, 2 and 3 are 0 (each field represents a time in minutes).
If the lock times are NOT 0:
Do NOT switch off the ignition!
Allow the car to sit for AT LEAST the number of minutes that were indicated by the fields 1-3.
If lockout time was present check Group 1.3 as mentioned above to confirm "Yes" is shown.
[Done, Go Back]
4-digit PIN
[Do it!]
[Adaptation - 10]
Enter 001 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
The old keys are automatically being cleared.
[Save]
[Done, Go Back]
Repeat the following steps until all keys have been matched:
Switch ignition off and remove key.
Insert next key to ignition and switch ignition on again.
The warning light for the Immobilizer will light up for ~2 seconds, then go out.
Note: The above steps after saving the adaptation, should not exceed 60 seconds!
wscar est déconnecté   Réponse avec citation
