Vieux 19/08/2015, 14h51
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
bonjours ,A3 pas de S tronich,que de la DSG,si tu vidange ,il y a un filtre au dessus de la boite,juste en dessous du filtre a air,bitier plastque,cle de 24 et remplissage par endessous ,mais faut un outil special,pourqoi tu vidange?normalement c est tous les 60000KM,merci.
magaratz est déconnecté   Réponse avec citation
