Vieux 21/08/2015, 17h24
magaratz
Avatar de magaratz
Pouvoir de réputation: 27
magaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud ofmagaratz has much to be proud of
bonjours,tu pulverise pres du collecteur admission et tuyau de depression et si le ralenti monte ou le moteur cale,c est qu il y a une prise d air,mais avant ca regarde ton tuyau du mastervac si il n est pas ffissurer,ca arrive souvent sur c est modeles la ,merci.
magaratz est déconnecté   Réponse avec citation
