Vieux 04/09/2015, 02h58
MrRorry
Avatar de MrRorry
Pouvoir de réputation: 77
MrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond reputeMrRorry has a reputation beyond repute
Hi, you will be not surprised that you have troubles with the can bus network. start from the beginning, check the fuses, condition of wires, voltage level on the ECU plug.
Also, i would check the ECU on the table if everything looks good with the wires and voltages.
Keep in mind that the car will never start until you fix this communication problem.
Good luck amigo
MrRorry est déconnecté   Réponse avec citation
