Vieux 06/09/2015, 22h19
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Hello again,
I have uploaded two Gearbox fault images recorded by Lexia interface:
1- Temporary fault, Pressure regulation (difference / setting). gearboxfault_1.jpg
This is the regular fault I used to receive, before the oil change. You will notice that this fault at temperature 56C, this is the highest it has happened, it usually happens between 20 - 35 degrees.
This is immediately after the oil change and overfilling by 0.45 Liter. It is the first time for this error to appears. It has happened when I kicked down (accelerator to the floor). I assume this is either because I overfilled or the oil was full of bubbles and has not settled yet. The second day I removed all the excess oil and overfilled by only 250 ml (0.25 liter), and tried to replicate the error but it never occurred again.
Type de fichier : jpg gearboxfault_1.jpg (92,7 Ko, 15 affichages)
Type de fichier : jpg gearboxfault_2.jpg (89,9 Ko, 15 affichages)
Simple est déconnecté   Réponse avec citation
