Vieux 11/09/2015, 23h48
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
For those who wish to install DiagBox 7.xx on Windows 10.. There are 4 points you need to consider for a successful installation:
1- Windows 10 automatically tries to use GPT, you may need to change to MBR, so that you can use IDE (Legacy) hard disk controller, else you will get the dreaded error 0.. Changing from (AHCI) to IDE may impose speed penalty; depending on your hardware. This is why I prefer using VirtualBox or VMware Player/Workstaion.
2- You need to install .NET 3.5 if you want to install DiagBox v7.66 or above. I also had Firefox and 7zip installed.
3- You (may) wish to plug-in the Lexia interface and install the drivers "ACTIAPnPInstaller.exe" before installing DiagBox v7.01 to ensure the multi-instance driver is installed.
4- You need to run DiagBox either as administrator or in XP compatibility mode for v7.74 and above. Otherwise you will get a message to reactivate
Type de fichier : jpg Win-10a.jpg (77,6 Ko, 53 affichages)
Type de fichier : jpg GBXa.jpg (81,5 Ko, 59 affichages)
Simple est déconnecté   Réponse avec citation
