Vieux 15/09/2015, 17h54
hamois
Avatar de hamois
hamois is a splendid one to beholdhamois is a splendid one to beholdhamois is a splendid one to beholdhamois is a splendid one to beholdhamois is a splendid one to beholdhamois is a splendid one to beholdhamois is a splendid one to behold
bonjour,
voila un "truc" sous DOS qui va peut-être t'aider :
"3. Asus BIOS password clear:
When you forgot the BIOS password, and can’t get into the BIOS settings or windows system, you have to crack it.
(1) Crack Asus BIOS password with command prompt
This method works when you can’t get into BIOS settings, but still can get into windows system.
Step 1: Get into ASUS computer DOS screen, type in the command after “C:WINDOWS>;”:
debug
– 0 70 10
– 0 71 ff
– q
Step 2: And then use the exit command to get out of the DOS screen.
Tips: Some of the BIOS versions are different, and the command above may not work for you, you can try with the program below:
Debug
– 0 71 20
– 0 70 21
– q
Use the exit command to get out of DOS screen, restart computer and press the Del key to get into the BIOS screen, and then you will find that you no more need to type in the password to get into BIOS."
sinon le mot de passe est conservé (encrypté) en NVRAM qu'il faudrait réinitialiser. retirer la pile + l'accu du portable + débrancher le secteur + appuyer sur le bouton power pendant une trentaine de secondes
en "prime", voila un lien vers tous les détails du BIOS AMI (American Megatrend Inc):
http://www.dewassoc.com/support/bios/amisetup.htm
d'autres astuces :
http://www.vodusoft.com/blog/simple-...bios-password/
pas con le truc n° 5 de juste changer la config !!
Dernière modification par akasa67 ; 15/09/2015 à 19h02. Motif: fusion
hamois est déconnecté   Réponse avec citation
