Vieux 16/09/2015, 11h47
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I tried Google translating your message in English, but I did not understand it..
Questions:
1- Are you installing Windows XP in a VirtualBox or on the computer directly?
2- Did you ensure that the Hard Drive controller type IDE?
3- If you are installing on Windows XP 32bit in VirtualBox, running on Windows 8 or 10.. No driver needs to be installed on Windows 10 or 8.
4- The ACTIA USB Devices driver should be "Multi-instance", but NOT USB Com board evolution driver (UMDF).
If your installation is on VirtualBox (Windows XP Virtual Machine off), go to Settings --> USB , you will see connected devices, and add the Lexia Device..
Start windows XP and you will see the device....
Now you may have to remove the driver from Device Manager and reinstall (Multi Instance) again.
Actia driver:
https://mega.nz/#!Nx8X2QQC!tB1i2eQCu...8yznTt0gdykA_0
plug-in the Lexia interface and click on "ACTIAPnPInstaller.exe" to install the driver.
Good Luck. Simple.
Simple est déconnecté   Réponse avec citation
The Following User Says Thank You to Simple For This Useful Post:
