Discussion: DiagBox v7.77 update
Vieux 20/09/2015, 15h36
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut DiagBox v7.77 update
Hello All,
I have DiagBox v7.77 working on the following platform: HP ENVY-M6, Intel i5, 8GB RAM, 1TB Hard Drive, running Windows 10 64bit (10547). DiagBox v7.77 is installed on Windows 10 x86 (10547) which is running on VMware Desktop 12 Pro.
I was surprise that it was easy to upgrade and make it run!!!, so I will perform some tests to see if it is fully functional before further writing on this matter.
Initial readings I got are similar to all previous versions... including the "Communication problem, in DB07.jpg" which I get (with all versions) every time I try to erase Injection Faults (only)... It seems a lot of people have faced this issue. Some are saying it is a fuse others are saying it is a loose connector. If someone has met this problem and solved it; feedback is appreciated...
DiagBox v7.77 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
Type de fichier : jpg DB01.jpg (85,2 Ko, 49 affichages)
Type de fichier : jpg DB04.jpg (42,3 Ko, 22 affichages)
Type de fichier : jpg DB05.jpg (93,8 Ko, 16 affichages)
Type de fichier : jpg DB06.jpg (40,6 Ko, 16 affichages)
Type de fichier : jpg DB07.jpg (50,4 Ko, 19 affichages)
Simple est déconnecté   Réponse avec citation
