Vieux 20/09/2015, 19h50
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
This is the same as mine:
http://www.aliexpress.com/item/Facto...74_75,201409_1
Lexia 3 Diagnostic Tool Description: (taken from the site)
1.It is compatible with Citroen cars including: C1, C2, C3, C4, C5, C6, C8, CCROSSER, NEMO, BERLINGO, JUMPY, JUMPER, AX, SAXO, BX and so on.
2.It is compatible with most Peugeot cars from 1995.
3.Diagnostics is performed via OBD-II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001).
4.lexia 3 Full Chip Firmware Serial Reference Number: 921815C/
Simple est déconnecté   Réponse avec citation
