Vieux 26/09/2015, 19h59
betrescudan
Avatar de betrescudan
betrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to beholdbetrescudan is a splendid one to behold
ok...i will write on english...my french is not so good
the china firmware 4.036 used on kess on market use token reset with only one token
what is token?...token is a .cfg file needed to be injected into nxp for renew the work...is practically a key to open the door to nxp LPC 2478
every token if you make comparition on hex ,are same...but not same hash
so...you can use only one time the token reset from china solution...after that,your nxp need to be changed
the 4.036 that you can find on variouses forums,is in fact the EU clones firmware...and work with the real tokens and real reseter for tokens...there are disponible reseter tokens with 10x30 tokens or 25x30 tokens
betrescudan est déconnecté   Réponse avec citation
