Vieux 05/10/2015, 21h25
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I cannot answer about NLC, but you can PM him... However, some posted the firmware and the flasher in one of the posts.. You can do it if your device has the optocouplers..
The firmware 4.3.3 is flashed when you start DiagBox v7.62 or above..
DiagBox v7.02 => Lexia Softwae Version= 500.46 & Lexia Interface Firmware = 4.3.0
DiagBox v7.57 => Lexia Softwae Version= 500.66 & Lexia Interface Firmware = 4.3.2
DiagBox v7.58 => Lexia Softwae Version= 500.66 & Lexia Interface Firmware = 4.3.2
DiagBox v7.62 => Lexia Softwae Version= 500.68 & Lexia Interface Firmware = 4.3.3
DiagBox v7.66 => Lexia Softwae Version= 500.68 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed)
DiagBox v7.74 => Lexia Softwae Version= 500.70 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
DiagBox v7.76 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
DiagBox v7.77 => Lexia Softwae Version= 500.71 & Lexia Interface Firmware = 4.3.3 (.NET 3.5 is needed, run as Administrator or XP compatibility)
Simple est déconnecté   Réponse avec citation
