Vieux 02/11/2015, 13h46
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Diagbox 7.77 (8.13) Update (en français)
Upgrade to DiagBox v7.77 (if you have upgraded to 7.76)
Please notice that this is intended for educational purposes and that you perform any or all the below procedures at your own risk. I hold no responsibility for any issue you may face.
Procedure (Offline Update):
1- Go to C:\AWRoot\bin\fi\ and create another copy of cashe folder naming it cashe.org.
2- Download the attached "updt_77u.zip" file, Expand it and copy the contents of the updt_77 forder to C:\AWRoot\dtwr\updt\ directly, replacing and overwriting existing files and folders.
3- Run DiagBox, it will start the upgrade process, when it finishes successfully click ok, it will run for the first time and will give 6 or 7 error message, keep clicking ok until DiagBox closes down.
4- Copy the 13 files that start with “fr.actia.AWF.xxxxxxx.dll” from cashe.org into the (empty) C:\AWRoot\bin\fi\cashe\ folder.
5- Run DiagBox and it will run successfully.
If you don’t like 7.77 update or you have an issue with it. Run Maitresox’s 7.74 to 7.76 again and it should successfully downgrade it to DiagBox v7.76.
I managed to switch the Language to French, I will post the language change Later.
Type de fichier : jpg DB1.jpg (39,4 Ko, 57 affichages)
Type de fichier : jpg DB3.jpg (87,6 Ko, 60 affichages)
Simple est déconnecté   Réponse avec citation
