Discussion: GQ-4X cd hs
Vieux 05/11/2015, 22h05
j-sky
Avatar de j-sky
Pouvoir de réputation: 143
voici le readme pour les drivers
Code:
GQ USB Driver V2.0.1
This USB driver works with GQ USB programmer software version 4.0 or later.
This USB driver is for:
1. Windows XP SP2
2. Windows XP 64 bit
3. Windows 2003
4. Windows Vista 32 bit
5. Windows Vista 64 bit
6. Windows 7 32 bit
7. Windows 7 64 bit
IMPORTANT: Install this driver before install the software.
           Because the software will install the Re.1.0 driver automatically.
If the USB driver v1.0 already installed, and the Windows does not install this driver,
then use update driver feature from the device manager for this driver.
The USB driver 1.0 and USB driver 2.0.1 have no different on programmer running speed.
En clair,
tu branches ton GQ-4X en USB
Tu vas dans le gestionnaire de périphériques
Tu désinstalles le driver
Tu fais une recherche de nouveau materiel
Tu lui indique le chemin de ton driver que tu as téléchargé
Et voilà !
Rappel des règles du forum
