Vieux 09/11/2015, 22h27
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Yes, you need Windows 32 bit... preferably Windows XP or 7... But I run it on Windows 10..
If you have 32 bit CPU (Micro Processor) Computer, then you can only run 32 bit Windows...
If you want to run DiagBox up to v7.76 on Windows 10, you need to consider are 4 points:
1- You are probably running Windows 10 on partition type as GPT, you may need to change to MBR, so that you can use IDE (Legacy) hard disk controller, else you will get the dreaded error 0.. Changing from (AHCI) to IDE may impose speed penalty; depending on your hardware..
2- You need to install .NET 3.5 if you want to install DiagBox v7.66 or above. I also had Firefox installed.
3- You (may) need to plug-in the Lexia interface and install the drivers "ACTIAPnPInstaller.exe" before installing DiagBox v7.01 to ensure the multyinstance driver is installed.
4- You need to run DiagBox as administrator or in XP compatibility mode for v7.74 and above. Otherwise you will get a message to reactivate.
Simple est déconnecté   Réponse avec citation
