Discussion: need fast response
Vieux 15/11/2015, 22h57
bahlsen007
Avatar de bahlsen007
bahlsen007 has a spectacular aura aboutbahlsen007 has a spectacular aura about
Im sorry but i dont have the wiring diagram of the ews module but have you check this :
main*fuse panel: check fuses*9, 22, 27, 29, 30*(ignition switch),*54*(fuel pump), and*14, 49, 67*(EWS).*
Inspect all fuses in the glove compartment if you're dealing with a hard to diagnose no start problem.
-*high amp fuses*above main*fuse panel*(fuseable links).*
There is an 80 amp for the DME and DME main relay, and a*50 amp fuse*for the ignition switch.*
Un Merci c'est gratuit et ca ne mange pas de pain :)
bahlsen007 est déconnecté   Réponse avec citation
